Are you a current or recent car shopper who bought an EV and then installed solar – or who had solar already, making the decision to go electric easier?
OR
Are you a recent EV buyer (past 3 months) as a result of manufacturer incentives and dealer discounts on these vehicles, including year-end deals? Were you convinced to buy an EV after finding a good end-of-year deal, or due to uncertainty around which EVs will no longer qualify for full/partial EV tax credits in 2024? A national business reporter is interested in speaking with you. Please reach out to [email protected] by 12/15 if interested in sharing your story.
OR
Honda Passport Timing Belt and Head Gasket
I have a 97 Passport with 147,000 miles on it, 3.2V6. It started making a noise like a belt with a bad idler pully; unfortunately it seems to be the timing belt rather than one of the accessory belts. While I have it apart that far I want to replace the left side head gasket, it has been leaking a little bit for a couple of years. Does anyone have enough experience with this engine to tell me what else I should replace while I have it this far apart?
I don't have the timing covers off but am pretty sure I will find a bad timing belt idler pully bearing or tensioner pulley bearing, does anyone have experience with them going bad?
I plan to of course replace the timing belt and all the accessory drive belts. I am thinking about replacing the water pump while I am there to, I presume they do fail sometimes. I think I will go ahead put on a rebuilt alternator too. The cooling hoses look pretty good but am always cautious about them, should I replace both radiator hoses and the other little hoses or are they not a problem? Any other hints someone with some experience with this model will be appreciated.
SUVs and Smart Shopper
the problem is when I start it up it idles at about 1200 rpm. If i let it sit for 5-10 min. it will eventually go down. I dont want to do this every time I start the car. any ideas?
Also, sometimes when I`m out driving the car will stall when Im idling. It has even stalled when I was just coastng down a hill. That was kind of scary because the power steering went out. It feels like the engine is not getting enough fuel sometimes.
Plus, its getting really bad gas mileage. about 12-13 miles/gal. I can visually watch the gauge dropping while I am driving. There might be something wrong with the gas gauge. It only takes 12 gallons to fill it up and its a 21 gal. tank if Im not mistaken.
Please help.
