01 sl check engine light
meredith01meredith01 Member Posts: 1
I have an 01 Sl. It's throwing a tune up code. I just had the spark plugs replaced but apparently the "mechanic" my x had fix it put in 2 different sets of spark plugs. Could this be part of the reason the check engine light is on?
  • bluesharpbluesharp Member Posts: 1
    i have a code coming up p0410 secondary air injection malfunction,.I have been trying to fix this with no luck.Everyting seems to be workin but the code keeps coming back.car will not pass inspection.any help out there?Thanks
    John
  • vestersad55vestersad55 Member Posts: 1
    The light is blinking I have checked all fluids, had the oil changed, once in a while another light on the dash comes on that I do not know what it is. I do not have a book to tell me what it is.
  • saturntech9saturntech9 Member Posts: 152
    A flashing check engine light is usually caused by a bad missfire what codes do you have?Also have you checked your plugs and wires?
  • saturnbluesaturnblue Member Posts: 10
    If it's what I think it is, it's probably the intake gasket is leaking air and that's causing your engine to constantly idle higher than usually at idle and your gas mileage is probably half of what you're used to seeing.
    I got the same code problem a few years ago and some posts on this forum pointed it out to me and I replaced the intake gasket myself back in 2008.
