95 olds aurora Idle problems
ChilliGeorgeChilliGeorge Member Posts: 1
edited April 2014 in Oldsmobile
Hello i have a 95 olds aurora 4.0 that will not idle below 3000 rpms this just started today any ideas of what may have happend and how to fix
  • ruffriderruffrider Member Posts: 2
    On the 95 Olds Aurora where is the ERG valve located on the transmission
    When the low oil pressure lite comes on when I come to a stop, does that mean I need a new oil pump. I have taken my car to the shop and had it serviced, but that indicator lite still comes on. If so where is the oil pump located and can I do the job.
  • meech31meech31 Member Posts: 1
    what can be the problem when it's idled to high?
  • blk97aurorablk97aurora Member Posts: 573
    Ruff,
    Probably not. The pressure sender is often the culprit. They cost about $25; buy only ACDelco. It is a black cylinder about the size of a roll of quarters located near the oil filter.
    If you have to ask where the oil pump is, do not consider replacing it yourself.
    Hope this helps.
    Les
