2007 Dodge GC Sliding Door Off Track
My 2007 Dodge Grand Caravan driver's side rear door was opened too hard and came off the track. Does anyone know of a schematics or diagram that will show how to put it back on track without having to take it into a dealership and spend big bucks? Has anyone had any luck with this?
When you say "off the track", what exactly do you mean? Is the door literally off the van, or is it just sitting in the door well?
1) pry off the plastic door sill protector - pull up on the inside edge, there are several clips on the underside and also plastic tabs on the outside edge and on the ends
2) remove the end stop (rear of the track) - it is a gold colored metal piece held on by two black hex bolts that go through the floor into the top of the end stop.
3) position the roller assembly (attached to the door) so that the bottom roller wheel and forward-most top roller is back in the track, while GENTLY pushing the door rearward and inwards, which should pop the rollers back into the track (it doesn't seem to matter what the position the electric cog/track is in - that will self-correct)
4) reinstall the end stop, test it (to make sure the electrical cable did not get damaged), and reinstall the plastic sill protector
I hope that helps.
Our door on our Chrysler T&C came off last night. I managed to fix it in about 3 minutes with the right tools, equipment and daylight without any assistance to hold the door while re-slotting the roller carriage into the rail.
Best Regards =-)
