Plymouth Grand Voyager Relay or Fues
fog37fog37 Member Posts: 1
My radiator fan went out. It has two cooling fans. What number fuse should I check and where's the relay? I don't know much about vehicles, so any advice will do.
Thanks very much in advance,
  • rx1nutrx1nut Member Posts: 1
    Can anyone tell me where this relay is located. The owners manual is no help at all.
  • vchengvcheng Member Posts: 1,284
    ....in the older ChryCo vans that I am familiar with, the fan control relay was either in the front driver wheel well inside the plastic liner or by the left (driver) side of the radiator.
    My guess would be to check the same locations first. I am sorry I do not know about the 2007 model, but I am sure somebody will chime in.
  • skykingdumb1skykingdumb1 Member Posts: 6
    I'm looking to find where the fuel shut off switch is located to reset it. It ran when I parked it,, now not getting fuel. It starts with a gas rag and runs until dried, but no gas getting thru. Inline filter off vehicle, and fuel pump not pumping. Any clues to this problem ,are appreciated
  • rcbsdrcbsd Member Posts: 1
    My air bag light on my instrument panel is starting to come on. When the key is in the ignition, you can turn it a little away from you, and the light goes out. This happens unexpectedly. Can anyone tell me what might be the problem? Thanx! :confuse:
  • biggiejbiggiej Member Posts: 1
    ive read some comments and tried the battery dissconnect but did not fix the problem. so now i want to try the fuse, but which fuse or relay takes care of the doorlocks, manual dont help either does a haynes manual
  • dno36dno36 Member Posts: 71
    When posting questions, please include Year, Make, Model, Engine of your vehicle.
