Nissan Pathfinder A/C Drain Problems
ryno2020usryno2020us Member Posts: 3
edited May 2014 in Nissan
I have a 2007 Nissan Pathfinder and recently noticed that the floor on the passenger side is wet. I did some poking around and discovered that the condensation from the AC is somehow draining into the cab. I cannot find the drain to see if it is clogged or disconnected. Where is the location of the drain for the AC in my truck? When the AC is running condensation is falling off of the frame almost directly under the passenger side floor. I am not sure if this is where the AC is supposed to drain. My warranty is up and I need some guidance to try to remedy this issue myself. Any Help is appreciated.
  • ryno2020usryno2020us Member Posts: 3
  • accrgaccrg Member Posts: 1
    I am having the same issue. Have you solved your problem?
    Paul
  • cmageecmagee Member Posts: 1
    Having the same problem/issue. Any solution?
    ChrisM
    Never found a solution to the A/C Drain problem. Since it is cold here in MD i am not using the A/C as much so hopefully by spring I can figure out what the issue is.
