2001 ford taurus vibration
Whenever i drive at a steady speed my car will start shaking real bad, it will do this on and off the whole time a maintain the speed. It doesnt matter if im going fast or slow as long as the speed is stead. Ive put in new spark plugs and new plug wires had all my fluids checked all filters have been replaced. I just cant figure out what is wrong.
It's hard to diagnose without a drive but here are some thoughts:
1) First, how long ago did this start? Any recent changes to the vehicle? (Sounds like you just did a tuneup, so maybe something wasn't reconnected)
2) If you get the car up to speed (like 30-40 mph) and put it in neutral and coast, does it still vibrate? If it does, the problem is probably in the chassis--wheels or tires, because the problem stays with the rolling elements. If it doesn't, it is probably in the powertrain, because when drive torque was eliminated, the problem cleared up.
3) Do you have custom wheels, or have you recently changed tires? Maybe it's simple, like poor wheel/tire balance, or possibly poor piloting of the wheels on the hubs. The on and off comment sounds like you have one or more tires out of balance--when this happens they vibrate in and out of phase and when they add together it can be pretty dramatic.
4) Are you sure the spark plug wires are routed to the correct cylinders? Maybe they screwed up your firing order.
5) Here's a flyer--been near any mud recently? I had mud dry in my wheels and the car felt like it was coming apart--I hosed out the back side of the wheels and it drove fine after that.
6) Finally, an unrelated tip--if the car sees road salt, have someone check your suspension springs at all four corners. These have a habit of breaking on Taurus (and lots of other FWD vehicles), and when they go they will tear up the inside of your tire and leave you stranded. Happened to us, luckily when the car was parked in our driveway.
Post back when you try some of these. Good luck.
1. Detach the hose from the heater core to the water pump.
2. Detach the hose from the thermostat to the heater core
3. Clamp the loop hose at the heater core.
4. Connect your garden hose to the hose previously detached from the thermostat.
5. Open your house garden water bib to flush the system. Watch the dirty water come off from the heater core. (3 minutes)
6. Connect all the hoses back keeping in mind you don't want air to get in those hoses again, so you have to work fast. Hope this help.
