Replacing TPM Sensor
I have an 05 T & C that has developed a Tire Pressure Monitor sensor issue. The display reads "1 tire has high pressure" and it alternates with "service tire system soon". All the tires have the correct pressure. I assume a sensor is bad. Two questions. How can I identify which sensor is bad and is replacing this a DIY job? Thanks
The sensor is built into the valve stem or banded to the rim itself. In either case, it means dismounting the tire from the rim to get at it.
