I just purchased a 2001 Olds Alero .. will I regret it?
I've done a lot of research and have found many positive and negative reviews on this car. It's a 2001, 4-dr sedan with a V-6 motor. It only has 57,000 miles on it, one owner, no accident or serious mechanical issues per Carfax. I took it out for a test drive and to my mechanic before buying it and the only problems they found were rear brakes and lower ball joints, along with the trac off light and service vehicle soon light being on. The body is in great condition, aside from two small dings and a little surface rust on the rear wheel well. The dealership agreed to fix these issues before I take delivery of the vehicle. I'm hoping that this isn't too good to be true and that as soon as I take ownership of it, things will go wrong. The price was reasonable and I work for the sister company of the dealership, so any issues I may encounter should be handled without a problem. Any suggestions, issues I should know about?
There are 135,000 miles on it.
The hood needs painted and the left rear door and quarter are dented, with the front dog leg rusting out due to the dent.
He is wanting $1,500.00 I am wanting to pay only $1,000.00 due to the miles and the work needed.
Tony
Other research tells me the worn hub/bearing is usually the opposite wheel of the turn--sharp right, humming from left wheel. Does this sound accurate? Any feedback is appreciated.
The worn bearing is usually the one you turn into (if you turn right and it makes a humming noise its usually your passenger side)
They are so easy to fix you might as well do both at the same time.
(1) front hub assemblies - which is an assembly supposedly sealed against the weather, and contains the wheel bearing and ABS sensor. Failure results in a grinding noise (wheel bearing) and/or an ABS sensor failure/warning light. The car drives and brakes fine when its just an ABS sensor failure - no ABS of course. Solved by replacing the hub assembly, which I've had to do every 40-80,000km when using CAD $300 A/C Delco or Timken hub assemblies - but price it out for where you live.
(2) de-lamination of the "fabric" on the dash with the dash structure beneath - strictly cosmetic
(3) brake pulsation, requiring turning down the brake discs and/or disc replacements. Once again, price it out for where you live.
(4) intake manifold gasket - chronic problem with all GM pushrod V-6 engines, plan to replace at least one at 100,000 miles
Other than that, my 3.4L V6 2009 Alero with 245,000km or 150,000 miles has the original radiator, water pump, alternator, power steering pump, brake booster, struts, auto transmission and the fluid levels do not move - no leaking or burning and I don't hesitate to drive it long distances. So altogether a quite reliable car, except for the points mentioned. Outside of the winter months I get 32mpg U.S. on mostly flat highway at 65 mph, and 28mpg in 50/50 mixed urban/highway driving.
