toyota 60k valve service?
i noticed that my owners book calls
for valve clearance at 60k i hae almost 90k,never been done ,and a timing belt and some igntion rotor and wires and cap, Question, Why des my g-friends chevy cavalier of the same year hardly reqire anything,
no timing belt,valves,belt tension,rotor ,cap?i thouhgt toyoats where more technically advanced,oh her cavaler is pretty much a base edition also and ideas?
butruns fine is a valve adjusment a needed thing,m 21 and found myself needing a good car after my other one
wrecked and i have to say this has been a good car so far 7 months though a little boring but given the recomendations on this car i dont care,and would plan on keeping it for awhile,any sugestions on how to make it last on a limited income? thanks brett
Different cars have different maintenance requirements; Toyota presumably knows what its cars need. "Technically advanced" does not equate to "you can ignore it for a hundred thousand miles", despite various automaker boasts.
It will also hold it's resale value while a used Cavalier is a car nobody wants.
Don't skimp on your car and you will reap the benefits of a 250,000 mile car.
These were supposted to be adjusted DEAD COLD but few shops would bother. Some shops and dealers would hook up a large fan under the car for awhile before adjusting the valves. Doubt if that helped much.
So, I would lie on my back, under my trusty VW bug and would check the valve adjustment. Rarely did they need to be adjusted.
