Chrysler Town & Country loses Power Steering in rain
in Chrysler
I have a 2005 Chrysler T&C Touring, what is the shield called that would prevent splashing from puddles to disrupt the steering belt causing the power steering to go out?
Ive had the belt checked as well as the idler pulley, etc, which are all fine, same with the drainage tube from the wipers, nada, so its coming from the undercarriage getting wet from puddles when we have the heavy downpours here in Florida. I know I can order via Chrysler but would like to price the part before I do so!! Thanks!
The problem as I see it, is there is no under-carriage splash-up that keeps the Universal belt from getting coated with water, which under load, is essentially a lubricant until heat melts it away, more or less.
I've played with putting different materials and "making" my own under-carriage tray that exists on both my German engineered cars (essentially a plastic tray), however I haven't found a way to make one that will not cause my transmission to heat up or the engine to operate slighly higher. I think this is because Chrysler has the undercarriage and front meant to "scoop up" air from underneath the car and spread it over the oil-pan, transaxle cover, etc. The problem with this, is water flows like are and will also "scoop up" under load, speed and just a few inches of water.
I am surprised no one has a solution to this in the after market world (I've looked, if anyone find one, it'd be great)....as of right now...driving this thing in the rain can get scarey if you go through some standing water (unexpectedly) and lose power-steering and are not very strong.
AUTO ) . I haven't done much research but they may have them in local auto parts stores.
I almost crashed a few times because of that so now i don't drive with my family in the rain
anymore until i fix their safety issue !!!!! I HOPE THIS HELPS !
