F150 thumping noise.
Why is it that when I partially depress my brake I get a thumping noise under the hood, when I fully depress it it stops? I checked the calipers and rotors and they look fine, the wheels don't shimmy or anything so I figure it is something under the hood just can't tell what.
Leakage test: Run engine. Without stepping on brake pedal, shut engine off. Wait 2 minutes then with engine off apply brakes. Should be enough reserve vacuum in booster for 2 brake applications.
