Mark VIII LSC?
syhuynhsyhuynh Member Posts: 1
edited March 2014 in Lincoln
Dear,
I am thinking of buying a 96 Lincoln Mark VIII from a friend. He says that his Mark VIII is a LSC model while I do not see anything in and out the car that show the word "LSC". So, can anyone differentiate the two models LSC and STD by just looking at the car? Please help.
Thanks a lot.
Sy Huynh,
  • kinleykinley Member Posts: 854
    I have seen a chrome "LSC" on the rear of a MarkVIII and I have seen the rears of MarkVIII's without the "LSC" The seller may consider he has a 'Luxury Super Coupe' for sale and thus it is an "LSC". However, it if doesn't say "LSC" on the back, it probably is the standard coupe. Either way it is a very good ride.
  • zandorzandor Member Posts: 67
    There's not much difference.
    Basically, the LSC gets a slightly stiffer
    suspension and real (vs. fake) dual exhausts.
    Also, for '96 I believe the LSC had HID/Xenon
    headlights. They should be obvious when they're
    on. If you see that "fancy car" brilliant
    blue-white light coming out of the low beams,
    it's an LSC. I'd also check for a JBL sound
    system. My Mark VIII's got one (standard in '98)
    but I think it was optional in '96. It's
    "very nice". First car I've had that would let
    me turn the volume all the way up w/o distortion. :)
    OTOH, I've never heard the base sound system so
    have a listen anyway.
    JBL won't help you tell the difference between a base & an LSC though.
    Other than that, you could crawl under the car
    and look at the exhaust system. However, I'm not
    sure if the base and LSC had different exhausts
    for 1996.
    In the case of my car (1998 Mark VIII) the most
    significant difference between the base and LSC
    is the look of the car. IMHO, the LSC doesn't
    come with enough chrome while the base is
    "just right".
    You should be able to find out more by going to
    www.markviii.org or reading through the "Mark
    VIII gone but not forgotten" group in Coupes,
    Convertibles, Sports on this board.
    You can also see some more owner comments here-
    http://cartalk.cars.com/Survey/Results/
    Another thing that might help you are these web
    sites-
    www.autoenhance.com
    These guys have locking replacement wheel center
    caps if yours get ripped off, though possibly
    only for the "lacy spoke" wheels.
    (I've got these wheels and yes the caps did get
    ripped off)
    store.autotoys.com
    Sells OEM compatible CD changers. This will allow
    you to add a CD changer to a car that doesn't have
    one without having to pay the dealer price or
    put up with having one of those stupid CD changer
    remotes glued to your dash. Also, they don't
    have the distortion problems of the FM modulated
    style of CD changer. They've also got the special
    tool you need to pop the head out (no pre-wiring,
    sorry). It's cheap, but you'll have to dig for
    it. (hard to find on the site & I forgot where
    it is) I think they call it a Ford Audio
    Extractor tool.
    The Mark's a wonderful car as long as you're not
    in the back seat. Have fun & good luck.
    Valentine activities process very well in the back seat.
