05 v8 Lincoln LS over/heating
Just had the Upper radiator hose replaced & thermostat & water outlet. My mechanic now thinks its a head gasket problem. When I drive it the temp gauge stays mid level then after a while will start going up.
Coolant isn't staying in the resivor tank but it's not on the ground either. The car only has 65K. If it was a head gasket isn't the temp gauge suppose to shoot up right away?
I had a head gasket problem with my other lincoln I had 10 years ago. I will never by another one again.
