Mazda5 Electrical Problems
in Mazda
When my headlights are on, the lights on the radio cut in and out when I move the steering wheel back and forth very slowly. Seems like the strain of the electric power steering is to blame. Not a big deal, but will have it checked out when my 5 is in for its first oil change.
David - :P Mazda5Lover :P
Has anyone else had this happen? Any suggestions on how to fix it?
Gideon
The second problem is the e-brake does not work every time. At first the e-brake worked great then when winter hit the brake would only catch 4 out of 5 times. When it did not catch the lever would go right up to the top, so it was easy to recognize that the brakes were not engaged, but not the dealership has adjusted them 7 times and I have found that only one wheel is locked 80% of the time.
Mazda Canada told me I don't really need an e-brake! and to just park the van against the curb or sidewalk and crank the wheels.
I live outside the city and I don't have a sidewalk, but I do have a long steep driveway, and three boys under 6 years of age... and no street lights.
I have left the vehicle at the dealership until it is road worthy and safe to drive again, I will also be starting an arbitration process against Mazda...
Any comments or helpful hints
I know this might not be the answer you are looking for, but I think you may not have been lucky with your existing dealer and with the Mazda Canada contacts.
Or another final idea, if you have very good evidence of course, is trying to drop and e-mail or give a call to Mazda North American Operations MNAO (they take care of CAN, US and Mexico, based in Irvine California and Detroit Michigan) or Mazda Global, who knows!
www.mazda.com
I figured if I just park the car and leave it alone for a while in my driveway, then, maybe, when I use it again it'll be back to working order. Lo and behold, when I turned it back on again a little later, everything was fine. Everything worked perfectly: radio, bluetooth, beeping sound, "Hello!" greeting and all. Strange!
The worst part of it all - the most traumatizing - was that the last song I heard on the radio before the radio stopped working was "Circus" by Britney Spears! AAAAAAAAAAAAAAHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!! The agony! It was TORTURE having that song stuck in my head!
So, anyway, has this happened to anyone before? (The whole radio thing, not the Britney Spears song thing - lol) What do you think it could be?
The dealer is uninterested in working on the problem.
I'm hoping it's gonna come back cause I can't live with no music at all. At least give me the radio! ;-)
I'll take it to the dealer if it still doesnt work tomorrow.
Anyone who had this issue got it fixed? By the way, any of you guys having any mods? I've got HIDs and I was worried if it could cause an electrical issue of some sort...
This happened over 20 times (i got fed up counting) over a short distance of about 8 miles.
None of the external lights seem affected, there is no problem with the power steering or power assisted brakes and the radio, windscreen wipers and heater all work fine. The indicators were a bit confused though, even though on the outside of the car they were indicating right, inside the car they were indicating left, then right, then left again.
It only seems to happen when accelerating from standstill to about 30mph and happens more frequently when the car is warmed up.
I have taken the car to the dealer who are clueless (not sure if this is the normal state for them or just because of this problem as I haven't tested them out before).
Any Ideas????
I hope this clue helps.
I will mention this to them tomorrow.
Did you manage to sort the problem out?
Thanks for the respose by the way :-)
I was just pointing out that the needles go up and down when there is low voltage in the dash. The cause in my case was a dead (almost) battery - user error.
In your case there could be a bad ground connection, a defective voltage regulator that suplies current to the instrument cluster or something else that lowers the tenssion.
One of the black covered wires to the dash (from underneath the manifold) had been cut somehow and was only allowing power through when the engine was in neutral or higher gears when it had less vibration. In lower gears the engine vibration was separating the two ends of the wire and causing the needles on the dash to go weird.
The guy at the garage (Simon) was made up that he had found the problem.
I was pretty stoked too :-)
Thanks for your help, the garage said it gave them the idea for looking at the wires.
I have a question of my own. I have a brand new 5. On the lower pannel over the left leg, driver side, very near the hood release, there is a small black... cube screwd on the plasric. There is a wire going from it in the back of the pannel. This seems to be added in hurry, like an after thought. It's not the ODB connector. Anybody knows what this is?
Aubie53
This morning I boosted it and within a minute it died again. I checked and all fuses are fine. Is this an alternator problem?
I called a local garage and he has alternators for Mazda3s and 6s but is unfamiliar with the 5 -- are these alternators interchangeable with the 5?!? As I would have to have the car towed to the garage I want to make sure I can get it fixed properly.
Please any insights or suggestions would be great!
Cheers,
Mat
And, yes, the alternator is most likely the same for any mazda with the 2.3 liter engine.
Edit: I looked on frugalmechanic, and they do show the same part number for at least 1 manufacturer for the mazda3 and mazda5 alternator.
This not an actual electrical problem - more mechanical, I think...
I plugged a cell phone car charger into the 12 volt power plug in the front and after awhile, I could not take it out. It would jiggle but not come out. So I crushed it, thinking the blades must of came out and "hooked". But I saw that the way it was designed made that assumption impossible. Oh well.... I bought another car charger, plugged it in and made sure it comes out (just like with the first). After a few days, the charger, again, does not want to come out. I actually pulled so hard on it that the whole cigarette lighter assembly was coming out.
Any ideas?
Tnx!
Andrew
Twice, the entire display has failed to work and doesn't greet with 'Hello'. In every case the fix is to turn car off and on again.
My front wipers are acting funny sometimes. When they are in the delay mode sometimes they don't stop at the down position but go past it and up an inch or two and then stop. Usually happens when cold or raining. The specific mode doesn't matter, usually I have them on auto, but it also happens if I swipe once.
Even during rain it happens sporadically....probably half of the time or so.
This is a canadian 2010 that I bought new in 2011. Very low mileage and wear (I work from home). I don't think it was doing it when it.was new.
So...anyone had this problem and what can it be? Wiper motor going south? I guess it wouldn't be a big deal to replace since there's a lot of used ones for sale.
Or can it be just a matter of gunked up electrical connection somewhere.
