GMC Yukon. Driver side brake is stuck and abs and traction control light are on?
americarodamericarod Member Posts: 3
edited January 2014 in GMC
Its only the driver side front the rotor looks bad and the caliper moves when i turn the wheel.. what do you recommend i do?
  • jordan40jordan40 Member Posts: 109
    best thing is get new brakes. depending on braking style. either new brake pads and/or rotors. if drum brakes new pads and/or drums
  • americarodamericarod Member Posts: 3
    Thanks i took it apart yesterday and discovered the hub bearing broke.
    good. well at least you found out what was wrong with it.
