Oldsmobile Intrigue just keeps cranking then tomorrow it will start lol
jeffreyscottjeffreyscott Member Posts: 6
edited September 2014 in Oldsmobile
my car just keeps cranking I have a Oldsmobile Intrigue 2000 it started out too crank for about 4 or 5 seconds then it would start now I went out there and it just keeps cranking if someone can give me a little help I would appreciate it thanks jeff and im a new guy on the block
  • ed_99_intrigueed_99_intrigue Member Posts: 2
    Hi Jeff, I just posted (yesterday) under ed_99_intrigue my experience with the ignition switch on my 99 Intrigue. Check to see if your service engine soon light (on the right hand side of the other lamps) is dim or even not lit at all with ignition switch on before cranking the engine. If it isn't as bright as the other lamps, I give a way to make the problem go away without replacing the switch. Good luck. Ed
