What Wheel Size to Choose?
I'm considering buying a 2014 Hardtop (my first Mini) and see there are a few options in wheel sizes. How does size affect handling and performance? Why would I choose a size larger than the standard 15" wheels other than looks? Why do some people make this upgrade?
Best Answer
MarkHolthoff
Member Posts: 101
Generally, people choose larger wheels to improve handling. This improvement mainly comes from the fact that larger wheels typically have tires with narrower sidewalls, so there's less flex in the tire when going around corners.
The tradeoff is that narrower sidewalls have less give when going over bumps, potholes, etc., which results in a more punishing ride.
Since most MINIs handle well with their standard wheels and tires, I would suggest sticking with those unless you are willing to gain a small improvement in performance driving capabilities at the cost of everyday drivability.
For more about this, check out How to Choose Tires and Wheels on Edmunds.com.
5
Answers
Thanks much. This is exactly the info I needed. Always good to know what the trade-offs are. Based on your sage advice, I will go with the standard wheels.
