2002 Isuzu Trooper 4WD Shifter
connornflconnornfl Member Posts: 1
edited April 2014 in Isuzu
I just bought a 2002 Isuzu Trooper (automatic) used. The car runs great, but whenever I try to manually active 4WD the shifter doesn't seem to be truly in 4Low or 4High when it claims to have activated. Also when I shift all the way up toward 4Low, the senser says it has moved back into 2WD. I am only curious as to if this is a common problem or if there are really more gears than only 4L and 4High.
