Saturn Vue Not Starting Since Replacing Thermostat And Camshaft Position Sensor
I just finished the daunting task of replacing my thermostat today. Just prior to that, I replaced the Camshaft Position Sensor. Both replacements were in response to trouble codes: Error code P0341 (camshaft position sensor), and P0128 (Coolant Temperature Below Thermostat Regulating Temperature). Car ran fine before the replacements, but now does not want to start. It turns over, but doesn't seem to be getting fuel. Can hear fuel pump priming with key turn. Also primed throttle to determine if a fuel problem - which it is.
If anyone out there has experienced this issue OR can tell me how to troubleshoot it down to a solution, I would be grateful!
Read more at: http://www.obd-codes.com/p0128
Copyright © OBD-Codes.com
