Dodge 2500 5.9 diesel auto trans.
popeye9popeye9 Member Posts: 2
edited May 2014 in Dodge
Been experiencing shifting problem with the O/D shift,,, in-out-in-out repeatedly.
Gotten worse now mayby 20 times p/mile !
Been scoutin and listenin & readin ,,come up with a grounding prob possibility !
I replaced the TPS and air temp sensor ,,no hup !
One fellow suggested to cut the wire (#4) on the TPS and run 2 new wires to a point on the emergency brake assemly for a new ground !
I would rather skin back the proper wire (?) at the TPS ) and solder and connect it to the emg.ped.[non-permissible content removed]'y
what do ya'll think ?
Additionaly make some fixes to the ground wires on the pass. side battery cables with shields etc.
Popeye9
Answers
  • popeye9popeye9 Member Posts: 2
    (non-permissable content= assembly,,, abreviated to [non-permissible content removed]'y)
    Sounds like you're on the right path of checking grounding. What year is your Ram?
