2003 odyssey engine light p1750 code?
abroome1abroome1 Member Posts: 1
edited May 2014 in Honda
Can I still drive van? If I replace ATF Selinoid is that going to fix the problem or is the transmission gone and need to be replaced?I am confused from what I have read I've gotting both answers. Low gears are skipping and rpms rev up. Please help me here with correct answer. Thank you!
Answers
    edited May 2014
    if you are ok with the transmission failing and stranding you, yes you can drive it. when it does strand you, the failure itself won't damage anything inside the passenger compartment. it is unlikely that swapping one solenoid will result in reliability or much further lifetime for an old/slipping transmission. earlier odysseys were known for major transmission issues even when they were new.
