Power steering system flush
in General
I was wondering if anyone had this done. I have heard a few people say it improved the steering feel afterwards. But I have only read of maybe 2 or 3 people who had it done.
The steering in my teggie is still great but the pump makes the grating sound like that of early 90's Fords. The only other real problem I have is sometimes on an extremely hot day when I am backing out it feels like the pump cant keep up. It shakes and makes the idle drop. Its kinda hard to explain but it happens rarely.
Would it be worth it to get the system flushed so to speak? Or should I just pass on it.
I went to NAPA and for $7.00 I bought the Lubegard Power Steering additive. It reduces temperatures and acids as well as lubricates better. I had the power steering flushed and Lubegard and new oil added. It smells much better. I found from my mechanic that they advise this process every 60,000 miles.
It seems to drive smoother and quieter, but they didn't have any problems that I could tell to begin with.
If you do the syphon and refill 2 or 3 times in a few weeks you will basically replace most of the fluid and save some money over a flush. Flushing can also cause problems by loosing crap up in my opinion.
My steering has felt funny for a while, which was partially fixed by a new steering column under warranty (I will soon get a new steering wheel as well because the leather is turning into mush). The column was making a dry squeak and it felt very unnerving when steering across center; it felt like it would completely loosen up at center/straight. Also, it sometimes makes weird noises. These still happen, but not as much now. I'm wondering if its my rack and pinion. Anyway, might a power steering fluid change fix some or all of this? Might it be a bubble in the lines?
A fluid change is good preventive maintenance. I would not depend on it to correct a steering effort problem or a noise, but in some instances it can help in that regard.
