97 Ford Contour Engine Noise
I just purchased a 97 Ford Contour SE and after driving it for a while I noticed a loud humming noise from the engine compartment. After investigating, I found that the noise is loudest at the filter box which leads to the intake manifold. The noise doesn't always happen, it is speratic. Can anyone tell me how to solve this problem.
Robert
Robert
Check to see if the air filter box etc. is on tight.
Go to www.contour.org for more info
This applies if you have a V6
