2000 silverado 2500
hondo10hondo10 Member Posts: 3
edited March 2014 in Chevrolet
i have a 2000 2500 4x4. I am about to put on a ranch hand front end replacement. I am wondering if anyone has cranked their torsion bars at all. I know that it will affect the ride somewhat. I am only thinking of 4 to 5 turns max. i would also like to put on 285's instead of the 265's i have now.
FYI, i have read numerous reports of problems people are having with their 6.0 engine. I have 21000mi on my truck.....no ticking at all. I do have knocking when i use the cheap gas. Change in gas and no problems.
Gracias
  • mledtjemledtje Member Posts: 1,123
    Bert,
    I turned my bars up 4-5 turns and got just over an inch or height. I took it in afterwards and had it aligned, it was in spec - barely. The toe-in was a little off, but I doubt the torsion bar had any effect on that.
    Mike L
  • hondo10hondo10 Member Posts: 3
    Mike
    thanks for the info. What size tires are you running? Will a 285 fit on that truck?
    Gracias
  • mgdvhmanmgdvhman Member Posts: 4,157
    may be a little too wide for the stock 6.5" rims...
    although it has been done with some sidewall buldge I would guess?
    255/85/16's are taller and a little skinnier
    - Tim
    I agree with Tim.
    285's are too wide for the stock rims. If you are changing to a wider rim you may be OK. A 285/75-16 is rated for a 7.5"-9" rim.
    A 255/85-16 is the same height, but rated for a 6.5" rim. Using the stock wheel offset and the 255 tire will eliminate tire rubbing.
    Mike L
  • van1390van1390 Member Posts: 2
    Does anyone else have a bad high frequency vibration at 75 mph?
    Mine is smoother at 75-80 than it is at 55-60. I do have a high pitched sound at that speed, but it comes from my passenger seat.
    Mike L
  • eric2001eric2001 Member Posts: 482
    Sorry, but I was laughing my [non-permissible content removed] off at your last statement. Thanks for making my night.
    -Eric
