Dodge Ram2500 or Silverado2500HD ?
Dodge Ram 2500 SLT with 5.9 or Silverado LS with 6.0? Reg cab/Long bed I am about to buy one of these trucks. I am having a hard time deciding which. I have owned a 98Ram 1500 2wd with a 5.2 for 3 1/2 years & am very happy with the truck. I want to increase my towing capacity a bit and get an increase in power. I will have to buy a 4WD, only because there is not one 2WD here in Denver to be had. I would like opinions on: 1. Which one rides better 2. Which does a better job of towing ( I often tow about 6000 lbs). Any other thoughts would be great!
-- Don
I know Randy is straight up because my family (Parents and Grandparents!)and I have dealt with him repeatedly at a certain Cadillac/Olds/Buick/GMC dealer in Boulder,where he worked for many years. In my opinion everybody worth talking to who worked at that Boulder dealership now works at Transwest. I don't know what we'll do when Mom wants to replace the '95 Fleetwood...I don't think she's going to agree to a GMC.
Though having said that if I can get a good deal on the Sierra and fair trade-in on my Ram I will probably buy the Sierra. I will be going to look on Mon. I DO like how the Sierra seems to sit lower than the 3/4 ton Ram. I am hoping the Sierra has a better ride than the 3/4 T ram.
I have a 1999 Dodge 2500 Quad cab with a diesel, 2WD, automatic trans, with ALL the HD options. This eng has a turbo.
I towed a 7,200 lb trailer about 17,000 miles/year for past 3 yrs. Drive about 20,000 miles/yr total. I avg about 14.7 mpg. including towing. I generally drive slower than most, in area of 53-60 mph.
I have towed up to 10,500 feet on steep grades and had very little difficulties. No overheating problems.
Think about the following:
1. Consider ordering rather than taking one from the dealer's supply. You get EXACTLY what you want. The delivery is in about 8-9 wks.
2. You can usually get fleet prices without haggling by ordering using something like the Costco plan. The price is so called dealer cost + $100. + about $300-$500 for something. It was about $2,400 to $4,000 less than prices I got 'negotiating' with a salesperson.
3. Does the Silverado new diesel have a turbo?
If it does it may have the power you want.
4. Why buy a 4WD if you can use the money to get an engine that will do the job.
5. My experience with diesel has been that it was about $0.10/gal less that gas in 1999; about $0.05/gal more than gas in 2000; and about $0.10/gal less than gas in 2001. There can be a big spread in some areas with up to $0.25/gal difference in price, generally diesel being cheaper on the big spreads.
6. The gas engine mileage I heard about from many persons pulling RVs that weighed about 8,000 - 11,000 lbs was in the 7-9 mpg range with 7.5 to 8 being pretty common.
Now I tow an 11,000 lb 5th wheel with a 2500 cummins Ram 4x2 and I love the truck. I see no need for 4wd, even though I live in upstate NY. Admittedly, the Cummins makes a lot of noise at idle, but at highway speed that noise goes away. It's quieter than the gas engine because I can run in OD 98% of the time and the engine just purrs along at 1700 rpm at 65mph. Mileage is 20+ empty and 13+ towing. I'd never go back to a gas engine for towing.
Dodge 5.9 245 HP @ 4000 RPM/335 Lbs-ft @ 3200 RPM
GM 6.0 300 HP @ 4400 RPM/360 Lbs-ft @ 4000 RPM
I haven't seen (couldn't find) a torque curve for the Dodge, but I offer the following observations about the 6.0L curves.
From about 2300 RPM to 4600 RPM the 6.0L torque exceeds the peak torque of the 5.9L (335 Lbs-ft)
From 3500 RPM to 6000 RPM the 6.0 exceeds 250 HP.
What this means to me, and what I have observed driving a friends 1500 HD is that the 6.0 has good power (torque really) at low RPM, but it really shines above 3,500 RPM. In comparison I would estimate (having not driven a Dodge 360 for quite a while now) that they are very comparable at low RPM, but that the Dodge begins to feel weaker above 3500 RPM, relative to the GM. That said I don't think I would spend much time turning more than 4,000 RPM with either of these engines, but it might be nice to have the extra power when trying to accelerate around a slow truck going up I-70, even just for a few seconds.
I rarely exceed 2500 rpm with my 2000 6.0L truck, it just isn't needed.
Mike L
Hunter
kip
I need all the help I can since I don't know squat about any of it. Lynda
