2013 Dodge Dart SXT Rallye Long-Term Road Test
edited September 2014 in Dodge
image2013 Dodge Dart SXT Rallye Long-Term Road Test
The tire pressure monitoring system alerted us to an underinflated tire and gave us a chance to bring all the tires up to spec.
  • fordson1fordson1 Unconfirmed Posts: 1,512
    "As I drove home I watched the pressure climb as the tires warmed up. Once I got home, I sprung into action." Well, I think you SPRANG into action, but what you did was check and inflate your tires to the cold psi spec...when the tires were already hot. This directly contradicts your own instructions from 2010 in the link you added to the post, and directly contradicts everything anyone knows about checking tire pressures.
    Really, Ed Hellwig doesn't realize that a TPMS is SUPPOSED to let you know when a tire is 5 psi low, and now you don't know you're not supposed to fill tires hot? And then you POST about it, like you're thinking how slick you are! *slaps forehead* - what is with you people out there? Is it something in the water?
