2014 Chevy Corvette Stingray Z51 vs. 2014 Porsche Cayman S Comparison Test
Edmunds.com
Edmunds' comparison test of the 2014 Chevy Corvette Stingray Z51 and 2014 Porsche Cayman S. Includes instrumented test numbers, lap times, on-road driving impressions, photos, video and more.
In contrast my GN came delivered w deformation in the roof from spot weld heat and pressure. The bolt was stripped and broken that held the air conditoner compressor (it is stuck in the compressor). Half the bolts and spacers are missing that attaches the unibody to the frame. So the body NVH is more and handling is not as tidy as designed. The black paint has white primer underneath that shows wherethe paint self destructs. The molding fell off. The roof liner is open cell foam backed that turned back to petroleum after 7 yrs same as my previous Camaro. The bumper liner cracked after 7yrs and fell apart. My car is parked in an insulated enclosed garage in San Diego. I covered it at work when i did drive it to work. The brake system is 1000psi electric and unique to GNs to provide braking for spooling boost at the start line when vacuum is unavailable. Almost every part needs to be replaced every 3 years at hundreds of dollars per part now that they are not a dealer item. The driver side header cracks every 3 yrs. I have under 70,0000 miles on this 28yr old Buick. They are actually considered to be the most reliable GM brand.
I would only consider a Corvette for performance and cost. I would really like to have a Porsche Cayman 3.8.
Idrove a 270 hp auto Boxster s on a track after driving a F1 equipped 360 Modena ferrari 390hp. I also drove the lotus elise 190hp 5 speed same track. I could not believe how good the Porsche was. It felt like 3/4 the speed of the Ferrari and just as tight and athletic. All the car you need. I was fully prepared to not like the ladies Porsche auto. The lotus sucked big time. No torque, clunky linkage squeaks rattles NVH of a kit car. I own a lotus 7 w a big block 2l 71 pinto engine souped up to the max, and tranny and the stock front pinto suspension and steering. It is much more direct acting.
