We are aware of the login problems affecting the forums, and appreciate your patience as we work on a fix.
Did you recently purchase a new Tesla, Rivian or Lucid vehicle directly from the manufacturer and willing to share how your experience compared to previous vehicle purchases made through a traditional dealer? A reporter would like to speak with you; please reach out to PR@Edmunds.com by 2/19 for details.
Nissan Altima Care and Maintenance
One salesman showed us this neat trick of the Altima 2.5SL ( I don't know if all Altimas have this), but you can do a check of the lights/horn/fan/windowwipers. I couldn't find a reference in the manual but it involved something like opening the car door and hitting the door frame button about 6 times...it goes through some sort of diagnostic check. I assume he had turned the car on to ACC but I was standing outside the car and couldn't really tell.
We bought the car at another dealership. We didn't do the test drive before we bought the car there because we had already had 3 test drives at other dealerships. The salewoman didn't show us this feature when we picked up the car because either A, she didn't know about it or B, it was cold and rainy and she didn't think about it.
Anyone else have specific insight into this?
Here is what our federal government has to say on this issue:
"In most cases, using a higher octane gasoline than your owner’s manual recommends offers absolutely no benefit. It won’t make your car perform better, go faster, get better mileage or run cleaner. Your best bet: listen to your owner’s manual."
http://www.ftc.gov/bcp/conline/pubs/autos/octane.htm
I plan on keeping the car at least 5 years, so we would be buying an extra 2 years of warranty.
Is anyone familiar with this warranty, it's offered by Nissan.
I'm currently looking at buying a 2003 Nissan Altima 2.5 SL. I love the car and everything about it, even if it has a few inside look draw backs. Reciently I was washing my parents malibue and noticed that no matter what I did the car still looked dirty, and always had water marks aprearing on the hood. I'm a bit of a neat freak when if comes to my car because I like my car to look like it just rolled off the lot that day. to many this is a pain to keep washing your car but to me it gives me great satisfaction in knowing that as I go down the road I get comments on how nice my car looks. if any one could please give some tips on washing advice I'd be very appriciative
Shop around and try the last day of the month.
Highest bid was $1600.00. I had 26k on my car when I bought the warranty.
"TIP: You can protect yourself from costly future repairs by purchasing an extended warranty -- Warranty Direct offers coverage at half the price that dealers charge." http://www.warrantydirect.com
Have never used myself, but worth looking into, I guess?
She has taken it back to the dealer once and they "blew out" the coolant lines---which didn't help anything (if they actually blew air into the heater lines, that could have made it worse).
Has anyone else run into this issue in the cold?
Anyone had experience with WarrantyDirect?
Warranty Direct
Check the Finance, Warranty, Insurance board for discussions of other extended warranty companies and issues.
filter should be changed once a year or every
12k. Anyone tried to do it yourself? If so how
hard is it to change.
I've got it too. Looks completely sharp but shows everything. I carry a lint brush in the console. I guess that all you can do it be vigilant about it.
Since it's summer, the car is not getting overly cold so I'm worried that something may not be getting lubricated correctly. Has anyone encountered this problem or heard about a TSB on this?
Any info will be greatly appreciated.
Is there a better way/ cheaper way to do it?
Since I dont use the car that much and it already has 125K miles on it (built in 1997) I was wondering if anyone could advice me of an efficient and cheap way to do it? If you guys feel that replacing the exhaust shall be the best way please feel free to say so.
Thanks a lot!
Suj, Minneapolis.
My '02 Altima is doing the exact same thing. Did you even figure out what it is that causes this weird phenomonon?
Do new pads all around at 22k sound premature? Has anyone else done this this early?
THanks
I just repaired similar problem myself.
You will need to spend about 1-1.5hours under the car, have enough willing to save 600 and have few basic tools.
What I did: Went to Pep Boys and purchased the following, pipe extensor (about $3 each) that is wider on one side than on the other. I bought 3-4 different ones and retured the ones I did not need after I picked the correct one. I also purchased high temp resistent gasket, high temp resistant silicone filler and 2 clamps
It was all about may be $15 or so.
Actual steps are
If the pipe actually broke of you put in gasket first and than after you figure out which extensor fits the best you connect 2 pieces together.
You may need to muscle the pieces far apart in order to insert the extensor. But because the exhaust is placed on rubber holders it is not a big problem.
Make sure extensor piece sits very tight, after that you put silicone at the places of contact of extensor and both ends of pipes to prevent any small leak of smoke from it. Than place clamps to secure the entire set up on both sides.
In addition you may try to somehow secure the exhaust to the body, (optional, - you can purchase connectors at the store as well for about $5-6)
This fix will last for some time.
I just redid the work again, about 6 months after I first did it.
You can also find a mechanic who would agree to meld pipes together. That would cost about $50, if done well it's the best but it may brake at the site of melding if not done so well. Of course if the pipe itself is very rusted, than sorry buddy you need to change the pipe.
I'm sure in that case you can find used one at the junk for fraction of $600.
Good luck
Misha
I am new to this forum and just wanted to share my experiences with fellow altima drivers. I currently have a 95 with approx:133k miles on it. I was driving from NY to NJ and suddenly on a stop light my car began to sputter, like when it is not getting any fuel or your out of fuel running on fumes. I looked in my Haynes repair manual for the specific vehicle and retrieved the DTC(diagnostic trouble codes) for my car. I came up with code 11 (camshaft position sensor (CPS)) and code 34 Knock sensor. Unfortunatley I cannot replace the CPS because it is integrated with the ignition distribution unit (THE DISTRIBUTOR). so now I have to replace it and guess what I think it will work. Moral of this story it's wise to consult your ECM (ENGINE CONTROL MODULE) and research the trouble codes for best car maintenance resolution.
I had purchased a 2004 VW Beetle Convertible GLS Turbo but I am so disappointed. It barely gets 15-16 miles per gallon. I had a Fuel Consumption Test done on it but the dealer says the computer it not showing "any faults" whatever that means so basically they say there is nothing they can do so I am selling it. As a result of this forum, it seems the VWs have a lot of problems so I am going to cut my losses
Any information you can give will be appreciated. Can I ask what you paid and where you live because in california we pay more for everything. I think they charge us extra for all the great weather and sunshine(smile)
That warranty you mention sounds pretty cool. If it is what thet say it is you can't go wrong especially if you are plannning to keep the car beyond the warranty period. Repairs can be very costly. I probably would buy an extended warranty. What is the warranty that comes with the car?
empi
