2005 Mercedes-Benz CL65 AMG Long-Term Road Test
edited September 2014 in Mercedes-Benz
image2005 Mercedes-Benz CL65 AMG Long-Term Road Test
First impressions of driving the 2005 Mercedes-Benz CL65 AMG.
  • zhangrenhouzhangrenhou Member Posts: 79
    I'm smitten by just looking at it!
  • firstshad0wfirstshad0w Member Posts: 0
    Gee, you may have accelerated a bit too fast on that on ramp - the post says December 26th!
  • fordson1fordson1 Unconfirmed Posts: 1,512
    I will never ever understand why car makers don't enable the seat memory controls until after you start the car. My wife is 5 feet tall. I'm 6 feet tall. I can lean in, crane my head around the wheel, angle my arm in, insert the key and turn, and then finally I can hit the seat memory for my setting in her '07 Toyota Sienna Limited. These controls are on the door - if I could just open the door and hit the button right there in front of me, it would be great.
  • mercedesfanmercedesfan Member Posts: 365
    The seats can be adjusted with the car off as long as the door is open. Once you close the door the car goes back to "sleep", if you will.
  • majin_ssj_ericmajin_ssj_eric Member Posts: 49
    Never have liked the seat controls on the door either Donna.
  • benson2175benson2175 Member Posts: 68
    Door controls on the door is actually brilliant if you think about it. Open the door, the controls activate, now with the door open and the controls easy to reach press your memory button and watch the seat move back because your wife was using the car before and had the seat way up and there's no need for you to squeeze into any uncomfortable positions. I could never go back to any other type of controls. Same goes for the clever cruise control stalk.
  • mustang5507mustang5507 Member Posts: 2
    Merc AMGs are so so tempting pre-owned. But also very very scary. I'll be following this one closely!
  • kevm14kevm14 Member Posts: 423
    On my 05 CTS-V, you can hit the memory and it will move everything (including side mirrors, radio presets and HVAC driver/pass temp settings). If the e-brake was set last, you can also press unlock from key fob #1 or #2 and it will change the setting accordingly before you even get in the car. However, no one drives my car but me so none of this matters. Also, the seat controls belong on the door. Lincoln did this back in the 80s and 90s, and the only thing natural about having the controls on the side is if you aren't sure if your particular rental car has power or manual seats (nevermind that manual seats have the lever in the FRONT of the seat). From a comfort/convenience standpoint, there is NOTHING convenient about fishing around in the narrow gap between the closed driver's door and seat. Even my 93 Caprice w/ police package has the 6-sway seat bottom controls on the door. Recline is manual and is a regular lever, though.
