2014 Mazda CX-5 Grand Touring AWD Long-Term Road Test
Edmunds.com
Edmunds' 2014 Mazda CX-5 is equipped with a new Smart City Brake Support system.
The wipers actually do move over the portion of the windshield where the SCBS is located. I can't speak to a dirty windshield since I clean my car every week. For the tinted strip at the top, the housing for the mirror where SBCS is located is actually quite large and flush with the inside of the windshield, unlike the system in the Subaru Forester where there is a gap between the sensors and the glass. So I assume anyone tinting the top part of the windshield would just tint the parts on each side of the unit.
Another observation I have on the system is that it will set off the laser warning on your radar detector constantly. I was getting warnings on my V1 every 5-10 seconds, so I disabled the laser warning on my V1. You're screwed anyways if you get hit with laser (unless you have jammers) so I didn't mind that much. At least it's not like Audi's where the blind spot system sets off the K band radar alert.
I first pulled each vehicle behind a parked car, and then pressed the accelerator. According to Mazda's web site, an alarm is supposed to sound on the dash, and the system is supposed to cut the accelerator if it senses the driver is going to accelerate into a vehicle stopped in front of the car. Neither of these things happened. I tested the same using different parked vehicles at fifferent ranges, and also with a concrete wall. Nothing.
I then tested the automatic braking feature while driving. According to Mazda, the car should warn of impending collision at speeds 18mph or less. (18 mph is very slow, by the way.) At 15 mph approaching a stopped vehicle, no warnings or automatic braking occurred from 100 feet to 5 feet of the target car. I had to manually slam the brakes on.
I also tested the feature to see if it would at least warn of a collision at speeds above 18mph. I approached a target car at a speed of 30mph and there was absolutely no peep out of the system.
I confirmed on both window stickers that the City Brake feature was installed, confirmed there were what appeared to be multiple sensors under the rear view mirror, and also confirmed features on the system right from the Mazda web site while the Mazda salespeople were reading over my shoulder.
What's up with this, Mazda?
