2013 Tesla Model S Long-Term Road Test
Tesla hasn't warned owners about extreme rear tire wear, and our long-term Model S tires are shot. The sunroof's broken again, as well.
Too much rear camber+low profile tires? One of the posts in the forum link is that the rear carries -2 deg camber, which is quite a bit for street use (especially since the car already has a multi-link rear). No provisions for adjustment in the links?
Then again, your impromptu leadfoot driving probably didn't help matters. I guess the techs dropped the ball on tire rotation if it's not on the invoice. But... this is a pretty big problem if they wear like this after 10K miles. Do you really think with this level of wear that tire rotation would have made much of a difference?
But it is expected that Tesla's will have a lot of little issues since they are new and small volume.
Interestingly, we can't find anywhere in the Tesla manuals or official online material a warning about that."
Honestly...you admit that the manual suggests tire rotations every 6,000 miles, then you make a statement like the above? You really think Tesla is going to make a statement such as "Excessive tire wear is common on vehicles equipped with 21-inch wheels and tires. Owners should anticipate replacing tires more frequently than owners of vehicles with smaller diameter wheels and tires."
No automaker is going to freely advertise such an issue and suggest that their $100,000 vehicle (or even a $20,000 vehicle) is going to have excessive maintenance expenses. If I knew going in that I would potentially be replacing tires at 10,000 miles simply because I missed one tire rotation, I would think twice about even buying the car.
That being said, the $375/tire price at the Tesla service center seems reasonable if that includes mounting and balancing. These tires are $288 each on Tire Rack, then by the time you add in shipping and getting them put on at an installer you are just about at the same price.
What surprises me is that given all of the tech in this car, it can't sense when the diameter of the tires drops 8/32" and display a warning. The tires start with 10/32", and the wear indicators show at 2/32". The tire essentially loses 1/4" in diameter by the time it is worn out. The car could use a sensor to detect the tire is operating at a smaller diameter than a new tire of the same size.
http://www.edmunds.com/tesla/model-s/2013/long-term-road-test/2013-tesla-model-s-burnouts-burnouts.html
Meanwhile the Model S is so much prettier with the base 19" wheels - and the ride presumably so much better - it's beyond me why anyone opts for the 21"s.
GM had an issue with heated washer fluid system that would overheat and possibly catch on fire. They could not figure out how to fix it. They discontinued the option recalled the cars with the option disconnected the system and gave owners a refund for the cost. This is what Tesla should do. Recall the cars with the 21" wheels replace them with the 19" wheels and give customers a refund.
@dunning15: "Bleeding edge" in some ways (to be clear- the most advanced part about this car is the chassis layout, even the battery/electric motor pack isn't very complicated but the way it's all laid together in the vehicle is quite different in design), but the suspension is somewhat conventional, minus the odd lower control arm on the rear. It's not rocket science putting in some level of camber adjust on the upper control arm.
@shepski: I have to agree with quadricycle. Unlike regular buyers of sports cars and such, I think the demographic that Tesla owners belong to probably aren't the type to do their own maintenance and simply take it into the shop. If the techs don't perform the tire rotation, they aren't going to know or think twice about it.
Here in western PA, I'm lucky to get 1/2 of the treadwear lifetime, even if I rotate.
In this case, I put most of the blame on Tesla.
/sarcasm
Also, looks like the inside flange is really beaten up from curbs...
