2013 Cadillac ATS Long-Term Road Test
edited September 2014 in Cadillac
image2013 Cadillac ATS Long-Term Road Test
The interior door panel of our 2013 Cadillac ATS has started to squeak.
  • zimtheinvaderzimtheinvader Member Posts: 580
    Sounds like the classic plastic against metal squeak. The thin material they put on the plastic in the areas it contacts the metal probably shifted. That doesn't make it any less annoying but hopefully they'll be able to fix it easily.
  • banhughbanhugh Member Posts: 315
    The problem with Cadillac is that their cars are based on the needs and values of the demographics of their customers from the last 10 years.
    No 80-yr old can hear that squeak therefore there is no need by Cadillac to find a solution for this in their cars.
    I hope the demographics change with the ATS...
  • diigiidiigii Member Posts: 156
    Classic GM build quality.
  • sharpendsharpend Member Posts: 177
    What do you expect for 'only' $48,566.68? But it did come with an iPad, woohoo!
  • juddholl10juddholl10 Member Posts: 84
    Another reason why buying American is stupid.
  • ballen0032ballen0032 Member Posts: 0
    Geez people, the early production runs had an issue, GM has a TSB to fix this, the later ones have been corrected during build. All it needs is a couple of metal door clips replaced with updated parts, a 10 minute fix. I don't think this qualifies banishing the vehicle to the heap list as some have suggested. FYI.... I own one and enjoy it so far.
