Visitor Agreement.
Here is where I get a little confused. The 195/55/15's revolve at 886 revs per mile. The 205/50/15's revolve at 899 rev per mile. 205/55/15's revolve at 870 rev per mile. How does this change in revolutions effect odometer readings.
-Larry
205/55 r15: approximately 1.8% slower.
both should be fine.
Best Regards,
Shipo
_Larry
by 8u6hfd
Tan, thanks for the feed back. A question, does the (205/50 r15: 1.6% faster speedometer) equate to the odometer showing more mileage than I actually drove? Conversely, will the (205/55 r15: approximately 1.8% slower) equate to less mileage showing on my odometer?
Respectfully,
Larry Kline
-Larry
If you have ABS, you could throw off the system a bit.
I'd replace all four if you were going to a different size, or order up one or two of current size and have them installed.
TireRack does have relationships with local installers. Or perhaps you can get the dealer to do it since they probably don't sell many tires. (If they have the equipment.)
TB
I'm either going with the 195/55TR/15 size Yokohama Avid T4 all-seasons, the 205/50TR/15 size Yokohama Avid T4 all-seasons, or 205/50HR/15 size Dunlop SP Sport A2 all-seasons tires.
My original question pertained to, how would changing from 195/55/15 to either 205/50/15 or 205/55/15 effect the odometer and the speedometer readings?
Tboner, I always enjoy your posts in the Smart Shopper Discussions.
Respectfully,
Larry
-Larry
The usual allowed threshold in variation is +/-3%
The other idea is if you're a warehouse club member, they usually offer road hazard and lifetime rotations and balancing for a low cost.
The 50 series tire will have a little more effect on speedo/odo readings but not dramatic. Here's the thing: Your current speedo likely isn't correct anyway. Very few OE speedos are calibrated perfectly. Heck, I recall reading one of the car mags testing a police version of a Crown Vic whose speedo was imprinted with "CALIBRATED". Guess what? The mag found it to be off by a mph or two.
Do you know where your speedo/odo is hooked to? Wheels? Transmission? Some place else? This discussion may be a totally moot point.
A change of a percent or two should not matter.
And yes, Sams Club is hard to beat for the full package price. Plus they can order tires not in the store, if you have the lead time to do this.
I had three tires repaired last summer, so I purchased my latest set of Michelins and Dunlops with lifetime balance and Road Hazard to guarantee I won't have another flat on those two cars. 8^)
TB
by bretfraz
Good Point, Bret. Nice to here from ya!
How is your Saab? Thanks again. :-)
-Larry
Tire Size Calculator
http://www.paspeedo.com/calculator.htm
