Fast & Furious 6 Cars: 1970 Ford Escort RS1600
edited December 2015 in Ford
Take a closer look at the 1970 Ford Escort RS1600 featured in Fast and Furious 6, including photos, video and more.
  • jederinojederino Member Posts: 0
    Nice to read about this fun little car. What is the redline on the Cosworth engine?
  • agentorangeagentorange Member Posts: 893
    IIRC these revved to about 7-7.5k. A couple of my buddies used to road-rally similar Escorts with a different powertrain. The rules in their class required a pushrod or SOHC 8V engine with a single twin-choke carb and the tyres were limited to 185/60. Even so, with some careful work you could make a quick and surprisingly civilised little car. Replacing the rear end arrangement of multi-leaf springs with single leaf springs, angled track bars and a Panhard rod greatly improved the ride and traction. Hardcore folk went to a three link or five link rear with coils at the rear. Bilstein shocks were de rigeur. Seam welding the shell and fitting a strut brace tightened the handling greatly too.
  • cosworthcosworth Member Posts: 3
    Even though no one on this side of the Atlantic knows that legend at all?
    Thats probably only true if you live in the US and then even if you have ever heard the word "rally" you know about the RS, 1600GT, Mexico etc. (Also, I think the Lotus Escort which preceded the RS was also 16 valve. It may have said Lotus on the valve covers but was the same Kent engine block).
    Limit is 12000 rpm in Champ Car World Series tune.
    Oops, Sorry...wrong info on rev limit but here is some good info. http://en.wikipedia.org/wiki/Cosworth
  • andyruandyru Member Posts: 1
    Sorry Guys, This is not a BDA RS1600 Escort, but a very good replica using NOT a Cosworth BDA but a Ford Ztec engine with a cam cover that makes it look like a BDA, And the Lotus twin cam Escort that the RS1600 replaced had the Lotus twin cam engine based on a Ford block but was only 8 valve not 16 like the RS1600BDA
  • vaffangoolvaffangool Member Posts: 6
    @agentorange:
    Mexicos and RS1600s were already seam-welded at the factory. The shells were strengthened to Type 49 spec at Halewood even before they were shipped to AVO.¹
    _________________
    ¹ http://www.rs2.co.uk/avo.htm
