2014 Chevrolet Silverado 1500 Z71 LT Crew Long-Term Road Test
image2014 Chevrolet Silverado 1500 Z71 LT Crew Long-Term Road Test
Fullsize pickups aren't the easiest things to park, but our 2014 Chevrolet Silverado manages adequately.
  • hybrishybris Member Posts: 365
    The fact that the Ram turns a full 7.7ft tighter seems to be leaps and bounds over the Chevy.
  • aspadeaspade Member Posts: 42
    The fact that the Ram turns a full 7.7ft tighter seems to indicate that you looked up the regular cab model instead.
    @aspade You may have a valid point but keep in mind that most truck makers use the same wheelbase where possible so a regular cab long bed has a wheelbase of say 133 inches it would be same wheelbase for a Crew cab with 5.5ft short bed. I can't say that's
  • okbeartoyokbeartoy Member Posts: 34
    Hybris while your information SEEM like it might be correct it isn't..
    These dimensions are easy to verify if you had taken the time to do so.. Ford F150 RC LB 133.3", shortest CC is 144.5" , GM RC LB 133", CC SB 143.5", Ram RC LB 140.5" CC SB 149.5".
    45.5' turning circle for the Ram Crew Cab 4X4 so not a huge difference after all..
