The 19s look so much better. I prefer the spoke design, and if you keep going down another couple inches there will be enough sidewall to make it look like a real car again.
@stovt001: Going any smaller would require some due diligence because of the brake caliper. The 19 inch wheels and tire sizes would offer a 99.75mm sidewall, which is a good compromise between sport and compliance.
You guys should order the same tires for this size rim, drive with them on (with another car following with the 20s on board) for maybe an hour/45 minutes to a favorite restaurant, then switch and drive back with the other set. That way you could do a write up with fresh and accurate information on the differences for anybody considering different size rims.
