Location of cabin filter on 2003 Toyota Tundra?
ransom1ransom1 Member Posts: 2
edited October 2014 in Toyota
location of cabin filter 2003 toyota tundra
Answers
    The cabin air filter is behind the glove box. Open the glove box. release the clip on the right side. Squeeze in the sides of the glove box to let the 2 catches in the rear get past the stops. The glove box will open all the way. Behind the box you will see a compartment door. squeeze the clips open and pull out the filter. Install a new one in reverse order. It's that simple. Filters cost about $20................................Good luck
  • ransom1ransom1 Member Posts: 2
    Hey Brian, thanks.. But I don't see a door to open, this is a 2003 Toyota Tundra access cab.. only thing visible is the AC vent and the heater channel.. Any other thoughts?
    edited October 2014
    You should see a slim door panel compartment w/ clips to open. If not I would call a couple of Toyota dealerships service dept. they will help you. . I'm sure you may be able to find a diagram of installation online if you google your model and year.
  • davebehrensdavebehrens Member Posts: 9
    There is no cabin air filter on 2003 Toyota Tundra. Not until '06-'07 do they have one.
