'97 Ford Escort LX wagon takes forever to get to normal operating temp.
on cold mornings i can't use heater until temp gets to normal operating temp. takes forever.
Answers
2. Forever is a long time. if it takes more than 10 minutes for your engine to reach normal operating temperature, the following is most likely to blame:
A. Your radiator is clogged full of rust/dirt. The coolant is not flowing very well. I don't think this is your problem. If it was, you'd be overheating in hot weather or in traffic. Could be an expensive repair, up to $500. See a mechanic and he can diagnose.
B. Your engine's thermostat ($5 part) is stuck in the open position. When this happens, the coolant runs around the engine / heater core so fast it never gets hot enough or takes a long long time to get hot. Have a mechanic install new thermostat ($100-$150 labor, possibly less)
C. Your heater core is clogged full of rust/dirt/gunk. The heater core is nothing more than a small radiator, just like the big one in your engine compartment (see A above). If your car is almost 20 years old then this is a very real poss that the core is clogged When was the last time you had your coolant system flushed by a mechanic? Make sure you direct the shop to BACK FLUSH your cooling system. It cam make HUGE difference.
Good luck!
