help, ABS pulsating noise, depends on tire wheel direction
ipogramipogram Member Posts: 1
edited November 2014 in Toyota
Every time I travel, and ABS do a self-test when reaching 10kph or so. I hear a loud noise coming from drivers front, where ABS actuator is also located.
The ABS noise is dependent on the tire wheel direction,and I am experiencing this for the past 3years. 3yrs ago, I thought the ABS pulsating noise is random, but then I was able to draw when when noise is less or at the maximum level. And I suspect the noise depends on tire wheel direction.
Noise is like gears rotating and does not clamp for around 1-2seconds. somewhat sounds like ABS pulsating as well.
I have attached an image of different case scenarios when ABS do self test on startup when reaching 10kph.
t happens ONCE every startup.. Have no idea why the ABS keeps doing that, or maybe it is not the ABS that is making noise... I already cleaned both Front Left and Right ABS speed sensors,but no luck, Rear is drums and I assume no ABS speed sensor.
And the pulsating noise, concides with my brakes pulsating as well, so I am pretty sure,my guess of ABS giving noise is around 95%..
[url=http://postimg.org/image/ewv9e99hl/][img]http://s28.postimg.org/ewv9e99hl/tire_movement_edited2.jpg[/img][/url]
