I have a 2002 Rendezvous having starting and stalling issues
daylite1daylite1 Member Posts: 1
edited December 2014 in Buick
I cant get it to start when hot and it sounds like it wants to crank and when it finally does it stalls sometimes . We have replaced the Battery, Fuel pump , o2 sensor, fuel sensor,Map sensor ect. It's still doing it cranks fine after sitting but still likes to stall when going slow . I really need some help bad.
Answers
  • Stalling at low speeds could be low transmission fluid.(among the possibilities) Not starting when hot sounds like a compression issue.
  • dgoines1dgoines1 Member Posts: 7
    I had a similar  situation  happen to me shortly  after i had the head gasket replaced and when the shop put it back together they left a wire laying on the block and made a short
