Hood Flutter - 2015 Chevrolet Colorado Long-Term Road Test
edited December 2014 in Chevrolet
imageHood Flutter - 2015 Chevrolet Colorado Long-Term Road Test
Edmunds.com conducts a long-term test of the 2015 Chevrolet Colorado and finds that the hood's sheet metal flutters when traveling at freeway speeds.
    I believe the hood is aluminum. Maybe a little thinner than it should be.
  • brenrobrenro Member Posts: 38
    Hope that paint has lots of flex additive.
  • DebunkerDebunker Member Posts: 49
    You think it's easy to design a hood that doesn't flutter?
  • quadricyclequadricycle Member Posts: 827
    Yes, quite. Though it becomes far less so when you have to hit a delicate balance of weight and strength.
    I'd say the balance should be on the non-flutter side. And if it was such a delicate balance, why don't more hoods flutter? First time I've ever heard of such a thing. You've encountered or even heard of a fluttering hood before? I've owned perhaps 25 vehicles through the years with nary a flutter.
  • glossgloss Member Posts: 150
    The Mazda CX-5 also has a bit of this. Your brain blocks it out after a little while.
  • yellowmiatayellowmiata Member Posts: 23
    Uncontrolled (or unaccounted for) vibration will eventually lead to stress failure. Any evidence of fatigue in the hood mounts?
  • dgcamerodgcamero Member Posts: 148
    Does it have adjustable rubber nubs at the front when the hood is open? Maybe one is too low?
  • oachalonoachalon Member Posts: 12
    There is a bulletin for this issue:
    http://sandyblogs.com/techlink/?p=4040
