2010 Grand Caravan Radiator Fan not kicking on
keithnm14keithnm14 Member Posts: 1
edited December 2014 in Dodge
My radiator fan is not kicking on. The fan motor is fine. I've replaced the engine coolant temperature sensor but that isn't doing the trick. The ratiator fan resistor has a crack in the green clay covering the coils. Could it be the fan resistor? How can I test if it isn't doing it's job? Maybe a heat gun to it to see if it will kick the fan on? Thoughts? Thanks!
