Lincoln LS down. Help
Car problems
1) Overheating
*but engine is warn not hot
*no boiling in the reservoir tank
*no heat is blowing out only cold air
2) the engine will cut off
*when i hit operating temperature If im at low rpms
3) horn and windshield wipers don't work
*Tested the the electric connection and found no power goin to it
*got a new wiper motor still didnt work
*all other controls on stick works with no problem
What i did
*Replace radiator and fan
*i try bleeding the cooling system when i open the breeder hoes white steam comes out
