Chevy Colorado ABS traction stabilization
grubpup927grubpup927 Member Posts: 1
edited January 2015 in Chevrolet
It is not consistent and sometimes will go up to 3 weeks before it malfunctions. On start up, on the dash display it will show ABS service, stabilization fault, traction fault. when this is showing ABS and traction system doesn't work. If I drive the truck at least 6 miles and turn it off and back on , then just the ABS service shows. After I start driving again and go only about 20 feet then the ABS wording goes out and everything works fine. The 2010 Colorado had 46000 miles on it when I bought it, it now has 56000 miles. It has been doing this since 48000 miles. I cleaned all sensors at the wheels and on the transfer case. When it does decide to do this it is normally in the morning at 5am. It sometimes but rarely does it when I get out of work at 430 pm. My drive to and from work is 24 miles one way. I did a check on the battery tonight and with a basic checker it says everything is good. I did a pile load test and it went to border line low. Any help would be appreciated
