Air Filter change
                    The air filter on my 1988 RX7 purchased at 72K miles was not recommended to be changed by the Dealer that serviced it from 78K through the last service at 108K miles. At 108K they did a scheduled maintenance and "looked at the air filter" and determined it was OK.
The second dealer in town had the car at 106k, 110k and finally 113k for four different repairs including 2 oil changes and they did not even look at the air filter they claim it is not routinely checked with oil changes only with scheduled maintenance. The result is that at 126K the air filter melted down and both dealers say they are not responsible for not recommending the filter be changed! The car is now totaled as the repair of the air filter system is projected at 1800 with no guarantee that the engine has not suffered irreparable damaged. I am angry that a minor repair/replacement cost of $25-30 could be overlooked causing $3,00+ repairs leaving the expensive alternative of purchasing another car.
Does this sound like negligence to anyone else? Has anyone experienced this with their dealer?
by mileage, none have EVER gone beyond 12,000, and that's on the recent square-style... the old GMs and Mopars with a circular filter on the carb, a big hole pointing forward off the air cleaner assembly, never went past 5000 on any car I owned.
so, yeah, I can't understand why everybody had "check filter" on their minds when "screw it, guys, put a new one in because I have the checkbook" would have been my response.
I changed my air filter to K&N @ 5k miles, (kept the old filter still looked decent) and at 10k cleaned and oiled it again(used the old one for a day to do it right) you wouldn't believe the crud that I washed off...
For normal air filters, last I heard was about 15k-22.5k something like that... Always follow the owners manual for MINIMUM maintenance. If you want to do it sooner, fine, but follow the owners manual for min's.
BTW, what happened between 113k and 126k? Did you do your own oil changes? If so, did you check your air filter? It "may" have looked fine at 113k but by 126k may have just deteriorated...
a tubload of gas in the crankcase from flooding the engine or bad rings could also provide gas fumes into the manifold for a backfire, courtesy of the PVC valve, couldn't it?
regardless, a clean filter being mashed by a backfire shouldn't dump a ton of dirt into the engine to grind it to bits. there might be some paper slop if it's really a window-breaker of a bang, but there would be very obvious debris in the intake and that should indicate that another issue is at fault here, not that air can't pass the filter cleanly.
