Phone Pairing Fail - 2014 Jeep Cherokee Limited Long-Term Road Test
edited January 2015 in Jeep
imagePhone Pairing Fail - 2014 Jeep Cherokee Limited Long-Term Road Test
This update to Edmunds long-term 2014 Jeep Cherokee Limited includes details on the SUVs malfunctioning Bluetooth system.
  • misterfusionmisterfusion Member Posts: 471
    Bluetooth pairing failures are annoying. I've had pairing failure scares with my own Uconnect system, but they were always cured by rebooting my phone rather than the car.
  • thecardoc3thecardoc3 Member Posts: 5,871
    There is one point here that needs addressed. In the past disconnecting the battery and clearing everything was a good idea and fixed a lot of issues. With newer cars that is actually a bad idea and should only be done if there is no other choice as there can be dozens of relearns that must be performed after a full loss of power. If you must de-power anything try and only do an individual system such as the radio in this case, or just a portion of the vehicle that is being serviced. Even then some relearns are only done efficiently with the support of a full O.E. scan tool.
    Will one of those 9 volt battery saver gizmos plugged into a power port be enough if you were going to spend 30 minutes doing a simple battery swap?
