2003 LeSabre Ignition Module
I've had to replace the Ignition Module 5 times in the past 7 months. They suggested the coil pack was making it too hot after number 3, so I let em replace that. No joy, 2 ICM later. Of course, now they're not wanting to warranty any more failures, so my question is this: what could be causing the ICM to fail?
Answers
Is it the correct part number?
Look it up in this list:
AIRTEX / WELLS Part # 2C7 $74.79
STANDARD MOTOR PRODUCTS Part # LX364T T-Series $99.89
UNITED IGNITION WIRE Part # DCM9607 106.79
DELPHI Part # DS1004 $125.79
STANDARD MOTOR PRODUCTS Part # LX364 $132.89
AIRTEX / WELLS Part # 6H1045 $135.79
ACDELCO Part # D1977A
{#10494012, 12617924, 19245558} GM Original Equipment
MODULE,IGN COIL $170.7
Is silicon dielectric grease needed where the ICM is screwed down to the engine
part to transfer heat? Is the engine part there clean of corrosion?
There are 3 coils on the car--they only replaced one?
