Towing Impressions - 2015 Chevrolet Colorado Long-Term Road Test
I recently used our 2015 Chevrolet Colorado to tow a Mercedes-Benz B-Class. Here are some impressions.
That's what tow/haul mode is supposed to do. It basically tells the computer that you want power not fuel economy and aggressive engine braking. You were going uphill in tow'haul mode and increasing throttle input. The truck downshifts to give you maximum power and you're surprised so you lift completely off the accelerator then surprised again that you're only going 25 MPH. So you do what the truck already did a few seconds ago and floor it to downshift for maximum power. The truck knew what it was doing the driver didn't. Towing 6,167 pounds plus the driver's weight and the weight of any other equipment or passengers (BTW that's 7,000-weight of passengers and cargo so you probably maxed out the truck's tow capacity) will significantly slow acceleration. This is why the transmission aggressively downshifts with the slightest increase in throttle. Sounds like the Colorado has excellent transmission programming.
