Airbag light always on.
schrizoschrizo Member Posts: 3
edited February 2015 in GMC
I have read all I can on an airbag warning light that is always on in my 05 2500 sierra. It throws the code B0026. From what I have read there is a 4 way connector (yellow) on the drivers side under the kick panel. I find a 2 way connector but no 4. I have checked the impact sensor under the radiator housing and it does show some resistance so I am assuming that is ok. I can't find any wiring under the passenger seat to check its connection. If you can help I would thank you ahead of time.
  • thecardoc3thecardoc3 Member Posts: 5,851
    B0026 is the drivers frontal deployment loop open. That's the drivers airbag circuit in the steering column has gone open. Common failures would include the clock spring, beyond that you really need a qualified technician to service this system since there is so much liability resting on its operating correctly should it ever be needed.
